Why won’t my tablet connect to wifi?
I have the Acer One tablet, and I have been able to connect to the internet fine, but recently it says no internet connection. How can I fix this?
One thing you can do try to fix this is to reboot your router by unplugging the device. Wait a few seconds before turning it back on, and then try to reconnect to the WiFi network.
Another option is to completely disconnect from your tablet's WiFi connection by turning the WiFi off. Once disconnected, turn the WiFi back on and try reconnecting.
If this still does not work, try changing the wireless channel on the router. To do this, click on the WiFi setting, and from the drop down menu, choose a different channel to see if the device will connect. You can check out the Acer One 10 S1002 145-A's troubleshooting page for more help on wireless connection issues.
I don't think that's the answer as my laptop and my wife's tablet works fine on the WiFi it's only my tablet which was working fine up to a couple of weeks ago that has the problem
I have the same problem
I have the same problem also
I didn't think unplugging the router and changing the channel was the issue either as my computer worked fine, but I did it and restarted my tablet and got wifi back! This solution worked for me.
I have same problem
@Cathy Moreau
I had this connection issue with my tab between zyxel vdsl modem.
I figured out how to connect wifi.
1st way
Just try to change pasword mode between somethings.(WPA2-PSK, wpa, etc.)
Then try connect your tab or phones to modem.
If it's doesn't work
The 2nd way little tricky
If you guys have the same possibilities in your modem's configurations..
You can give a shot my 2nd way too.
I created Guest account without password.
I changed some options for my Guest Account for some security.
1-) I hided my Guest Account's SSID. (invisible SSID) (just give a easy words or things to name on it about invisible SSID for you can remember always)
2-) I Changed MAC Authentication's MAC Restrict Mode option to Allow for my invisible Guest SSID. (just add 1 mac id adress. I mean, add your phone/tab wifi mac id adress to your list)
I added my tab's Mac IP adress to allowed Guess Account's mac filters.
Then i added my invisible SSID's name to in my tab wifi's netwoks option.
I connected my tab to modem easily
Dernières 24 heures : 5
7 derniers jours : 11
30 derniers jours : 55
Total : 57,427
10 commentaires
Student Question
par mayer
Everything is connected to the WiFi at my house expect for my Samsung Tablet which I been trying to connected all night like keep restarting my tablet and reconnected the WiFi on my tablet it was working fine yesterday afternoon while I was outside but then last night the WiFi started not to connect.
par mariahgirl93
my problem as well
par canada2goose
Acer 10inch tablet won,t connect to
par tcruickshank6
Add me to the list. A few weeks ago my provider switched to 5G. Phone ,computer all automatically connected ,not my tablet.
Tryed everything please help
par Michael Hardy
Voir 5 commentaires en plus
