Aller au contenu principal
The model WD50FB2530 is a television produced by Westinghouse Electric Corporation.
Questions au sujet de 1 Voir tout
How do I select OK manually without a remote?
How do I select the function OK without a television remote? I need to retune the tv (and have even bought a universal remote) but I still have to do it manually i.e. On the display itself. Tried every option, please help!
Répondre à cette question J'ai le même problème
Indice 15
27 commentaires
Neither of these options work, and programming a universal remote control is useless. The codes do not enable the use of the OK button which is critical to the OTA programming of the HD-56FH9* Model JVC TV. This seems to be a collosally huge oversight by JVC, their imbedded buttons on the side of the TV are just as worthless as the the engineers who made this mistake.
So to JVC I say WTF
par
Did u ever fix ur issue? im having the same problem.
par
Did mine by pressing both up and down vol buttons at same time, menu butt first then channelbutt for Auto tune then both vol buttons for ok
par
Have a jvc tv with bulit in dvd and freeview no remote how do i setup
par
How can I turn on my TV without my remote control?
par
Voir 22 commentaires en plus
Ajouter un commentaire
6 Réponses
Réponse la plus utile
use both volume buttons at the same time.
Indice 11
7 commentaires:
I went an bought a universal remote as well. Britney’s comment end up working though. Thanks!!!
par
Thanks so much!!
par
Thankyou i had this problem spent hours trying to work ot out pressed up and down volume buttons at the same time and worked perfectly xxxx
par
I have a telefunken tv and I have tried to press the up and down volume buttons but it's not working or how long should I wait when pressing the buttons.
par
I have a hisense tv there are volume buttons - up an down buttons- a tv off and a input button so 7 buttons but no ok button what should i press for the ok button
par
Voir 2 commentaires en plus
Hey Josh Paradise,
Most of the times it´s the menu button itself wich you can find on the tv.
Indice 1
2 commentaires:
My TV has no buttons at all on the set itself and I can't find the remote control anywhere
par
My problem, exactly. My power button only toggles the input source up and down
par
On the JVC model HD-56G786...
In order to press “ok” without a remote, I had to hold the “menu” button on the right side of the TV, and while holding press both volume buttons at the same time.
Indice 1
2 commentaires:
What if button on bottom no buttons on the side?
par
What if the menu button is the same as one of the volume buttons?
par
I guess there are many different ways to change the input without a remote control then, because I changed my input by pressing volume up THEN very quickly, channel down
Indice 1
1 commentaire:
I have a GPX and I also get to scan channel but idk how to make it scan I tried to press ok to start scan but didn't work what is the button you press to get it to take yes
par
Hi @rundrummergirl ,
Looking at the user manualfor your series TV you need the remote control unit or a universal remote to do most of the functions on the TV including setup.
Indice 1
2 commentaires:
I have a alba Freeview/dvd TV. Lost the remote. How do I change channels, on the side there is an on/off button, volume +/- buttons and one to change modes(TV/dvd etc). Got a universal remote but won't work!!!!!!! HELP
par
@Elaine Hannigan
What is the model number of the TV?
Looking at a few of the user guides linked there are program channel up and down buttons. You just press them and the channel should change. You would need to press more times to step through each of the stored channels in the TV in the order that they were first stored, to get to the one that you want.
Did you enter the correct TV code into the universal remote?
par
I had to autoprogram channels on my Emerson TV without a remote. First, press menu and then follow the up and down commands. Next, press the volume and menu buttons at the same time to signify, “OK” or “Select”. That’s what worked for me so I hope that helps someone else!
Indice 0
5 commentaires:
I have JVC TV Model LT-32DE75 need to operate without remote
par
I have my DVD stuck and I switch TV on it operate I don't have remote control how do I pull out the DVD without remote
par
Need to find or buy a jvc tv remote with the 3D option... Cant find any
Or how to put on the 3 d option
par
Please how can I select language without my TV remote on skyworth 32inch
par
Have already reset my TV
par
Ajouter une réponse
Josh Paradise sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 53
7 derniers jours : 359
30 derniers jours : 1,656
Total : 226,111
