Serious iPhone 5 battery problem
I have a iPhone 5 that had a battery problem. My screen popped out of its housing because the battery was expanding. I replaced the battery as well as the screen because it had been damaged by the expanding. I bought a new battery from a trusted online store. It's called MyTrendyPhone and operates in Norway where I live. I also bought a screen on eBay.
Everything worked out well and it has lasted for many many months. But know I noticed that ONCE AGAIN the screen is popping out. I suspect the battery is expanding, but I don't understand why. The battery is under one year old and everything has worked out well before now. Does anybody know what this is???
The first battery that expanded was the original battery that came with the phone.
The second battery was bought as mentioned.
http://www.mytrendyphone.com/iphone-5-ba...
(the same battery as i bought from MyTrendyPhone Norway. Original link in Norwegian: http://www.mytrendyphone.no/shop/iphone-...
I just want to know why a almost new battery can expand???
NEW UPDATE 12. DECEMBER
The screen is popping out more and more. But today i noticed that the screen is semi-back to normal. I noticed this after i was out in the cold norwegian weather.
I dont have words... DOES ANYBODY KNOW WHY THIS IS HAPPENING??? PLEASE HELP!!!
Illustration picture:
Very first:
Then:
And then:
And now:
5 commentaires
hi daniel, i have experience many times like your case of expanding batterys in iphones and other brands of mobile. even you change the battery many times it will expand, it is because your logic board or the mother board of your mobile has a shortage. only a good technician can check your mother board using a power supply. hope it helps you.
par rey montaniel
how do you know that if the mother board has a shortage and if it has, what to do to fix it???
par Daniel Kendel
Are you using original charger? Do you have last OS installed ?
par Juan Pablo Roldan
Yep, im using original charger but im on iOS 9.3.5
par Daniel Kendel
par Daniel Kendel
