Aller au contenu principal
Annoncé le 16 Octobre 2014, identifiable par le numéro de modèle A1347 et EMC 2840.
184 questions Voir tout
Adding a HDD to SSD PCI flash based mac mini late 2014
Hi the posts on similar subjects seem to be 2 years old and I can't find a good on-line resource.
I have the late mac mini 2014 model with PCI flash only. I want to add a hard disk drive to increase internal storage and create a single fusion model.
Can someone confirm whether this is possible and which kit in need to buy. I've understood that the sata cable for the HHD is not included in the PCI-only version.
Many thanks
Répondre à cette question J'ai le même problème
Indice 3
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Yes, you can add in a HD drive in an Apple blade SSD based system.
Here's the IFIXIT guide you'll need to follow: Mac Mini Late 2014 Hard Drive Replacement and you'll need this cable, screws & bushings, as well as the needed tool: Mac Mini Dual Drive Kit.
As to creating a Fusion Drive you'll need to run the command line argument following this article: How to create and disable a Fusion Drive
Image Mac mini Dual Drive Kit
Produit
$26.99
Indice 3
4 commentaires:
I managed to add the second SSD using the iFixit kit and teardown (great product/pictures).
I have an issue with the fusion. Even though the mini is SSD-PCIe only, there is an existing CoreStorage volume. I don't think I can add a second HD to an exisiting corestorage. Do I need to delete it and create a new one from scratch?
Or is it best to reinstall from the recovery and overwrite with my latest time-machine backup?
Thanks for any support :-)
par
Opps! You can't create a Fusion Drive set with two SSD's! But you can run them independently.
The rub here is how the OS see's the drives. Think of it this way I have a Red (HD) drive and a Blue (SSD) drive each is weighted differently within the OS (HD Vs SSD).
Now instead of having two distinct drives think of having two Blue drives! Which Blue drive is the base drive?? No, its that Blue drive, No! It's that Blue ;-}
You'll end up having a mess! This is only an issue within the system. You can create RAID sets with external drives as they use their own drivers.
par
No worries. I have another HDD, I thought I'd be clever! MacOSX doesn't add the HDD to existing corestorage volume (must be factory installed on PCi SSD-only as I didn't make it). Can't find a way to add HDD to the volume, so is it best delete the corestorage volume and recreate from scratch? Thanks!
$ diskutil coreStorage list
CoreStorage logical volume groups (1 found)
+-- Logical Volume Group 88E23BEE-0320-4FCF-B327-9ED9A8F3E5E8
Status: Online
Size: 250139852800 B (250.1 GB)
Free Space: 8921088 B (8.9 MB)
+-< Physical Volume 550E2DD7-00ED-4A0E-B16A-E43EED6E72E3
| Index: 0
| Disk: disk0s2
+-> Logical Volume Family 1B0792DB-B6CF-4CFA-BD5F-63C70C2A10F5
Encryption Type: None
+-> Logical Volume A7E18B5C-8852-4B06-B4DC-B7C8E38C2010
Disk: disk2
etc.
HDD is on /dev/disk1
par
In the end I resolved my issue so I'm updating this post for others.
(1) ensure an additional complete backup on Time Machine
(2) Reverted the CoreStorage volume instead of deletion (https://support.symantec.com/en_US/artic...)
(3) create the fusion drive per instructions in the above post (http://www.techrepublic.com/article/pro-...). In my case I did not build a fusion drive with the full disks (i.e. /dev/disk0 and /dev/disk1), I selected the specific partitions hoping to preserve EFI and recovery partitions. In my case, it meant pointing to /dev/disk0s2 and /dev/disk1s2
(4) Reinstall the fusion drive from the time machine backup.
This was done on 10.12.2 before updating to 10.12.3. 10.12.3 did not break my fusion drive
par
Can someone confirm that the "Mac mini dual drive kit" linked to in the reply is what you need to add a hard drive to an SSD only 2014 Mac mini? The page for that kit says it is for 2011 and 2012 Mac minis, it doesn't mention the 2014 at all.
Indice 0
2 commentaires:
That's the kit I used as suggested by Dan. Follow the above 4 steps I described if an existing corestorage is already active. My late 2014 SSD-only mac mini already had an active corestorage, the Symantec page explains everything!
par
Were you able to add a SATA HDD/SSD to a PCIe only Mac Mini? I tried but it doesn't recognize the SATA SSD? Please help.
par
Ajouter une réponse
Ceraz sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 2,549
