got screws all mixed-up hard to reassemble
is there a screw size chart for that device?(3gs) and how do I get it?
there are tons of video on youtube when you put in the search bar "dissasembly / assembly" and your device name.
usually are HD videos, so it can help you identify your screws. had similar issue with some screw from iphone 5, just take the smallest and go for the smallest holes, screw and turn around. if they don't fall out, it's probably the correct diameter. try to @%^!* the length depending on the place where you put it. closer to the case is smaller screw.
Download the IFIXIT APP it will tell you step by step instructions and each screw size. A micrometer will be handy
@davey3t , David check the links below from ifixit Replacement guides, a lot of the screws are identified in the assy. of the 3G. Good luck.
Remplacement de la coque arrière de l'iPhone 3G
Remplacement de la carte mère de l'iPhone 3G
more guides for 3G below.
Tutoriel
Difficulté :
Modérée
Tutoriel
Difficulté :
Difficile
2 - 3 hours
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 413
