The backlight fuse is in the area to the right of the keyboard connector, brown with a little "P" on it. With the battery disconnected, measure continuity on the fuse, if it beeps it is good.
You can replace this with just a soldering iron. Touch one side of the fuse, and make a ball of solder, until it surrounds the fuse. Depending on how good your iron is at putting power down, it will eventually pull the fuse off.
Before soldering a new one on, check continuity to ground on both fuse pads by putting one probe on a screw hole and the other on a pad. If there is a short (beep) on one side, there is something shorting that side to ground, which is why the fuse blew. If this is the case, you will have to find out what is causing this to happen (will get into this if this is the case).
If there is no short, put fresh solder on the pads (not too much, since you are not using hot air, you want to keep it fairly even) and then solder both sides of the new one on, using tweezers to hold the fuse.
Before powering on, check the LCD connector and cable to see if there are any burnt pins or melted plastic, this will likely blow the fuse.
Add a picture of the damaged area, and I'll help out :)
A voté
Annuler
Indice
2
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
