2006 Ford Focus sed driver and passenger power windows are not working
2006 Ford Focus sedan driver & passenger power windows are not working, fuses have been checked and are ok, what else could be the problem?
@jerryt , Jerry Taylor, Do you here ant clicking at all to say switch is trying. Recheck all fuses to ensure they are all OK. If the switches work on other doors for windows, chances are the driver side main switch panel is defective or power wire/plug damaged/corroded you can test the switch with a 12 volt test light or a DVOM, quite often over time the wires in the harness between the door jamb and door frame get damaged(peel back wires protection to check/test) or there is a slight chance that pwr. windows motor have failed on both doors(uncommon but could happen). See below trouble shooting links for diagnosing/testing for power window issues and removal of interior door panel. Good luck.
https://www.youtube.com/watch?v=2tLmH05U...
https://www.youtube.com/watch?v=aT3Gjpqm...
i just replaced the motor on drivers door 6 months ago.
just front windows are not working , can it be a switch?
or fuse 2005 ford foucs
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 5,035
