Accidentally replaced LCD digitizer without removing battery first
Hello,
I was wondering what I can do to power on my ipad mini 2 after I have replaced the LCD digitizer without removing the battery flex cable first? I read on the forum that you are supposed to put the battery cable on last after placing the LCD digitizer cable.
Also read that I may have to replace the fuse, which I'm not quite sure where it is located.
As of right now, the ipad is recognized on my laptop but, it doesn't power on.
2 commentaires
If it is the backlight circuit needing troubleshooting the iPad should still display something but very dim.
Usually backlight filters / fuse / chokes (I think they are called) need to be checked for continuity via a digital multimeter.
par Ben
Also you can hold a flashlight over the display, and see if you can still see the display
par iMedic
