Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sorti le 24 juillet 2014, le Fire Phone est le premier smartphone d'Amazon, conçu pour concurrencer les appareils iOS, Android et Windows Phone.
Wifi signal weak after battery change
After replacing battery in amazon fire phone, I was unable to connect to wifi weak signal. it pick up signal only within 1 foot from router range. And also not full signal..
any suggestion what I did wrong during battery replacement process.
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
4 commentaires
This is just a guess after looking at the tear down on Ifixit. I would be looking at the flat antenna connections and making sure they didn't come loose. It looks like you could easily catch the antenna cable with the adhesive strip you pull out from under the battery.
par
you are talkin about the black strip cable...
par
I have this problem too. Can anyone solve it for me?
par
I check all the strips also antenna cable which is perfect, not loose but facing same problem very weak signal of wifi and Bluetooth this all due to replacing my fire phone battery.
par
Ajouter un commentaire
1 Réponse
Solution retenue
Hi,
Here is a link to the Ifixit teardown for your phone.
In Step 7. of the teardown it mentions flat antenna cables, just after removing the battery. Perhaps you loosened their connections when you removed the battery.
Vue éclatée de l'Amazon Fire Phone
Hopefully this is of some help.
Update (02/03/2017)
Hi,
Here is an image showing the actual connectors. Check that they are both OK.
(Click on image to enlarge for better viewing)
Indice 5
19 commentaires:
Haha. I was just commenting about the antenna cables. I must have clicked on the question just before you answered, and my screen hadn't refreshed.
par
or the golden strip you are talking about
par
Hi, It may be both as it mentions cables (more than one)
par
I checked it all the way.. black strip and golden strip are tightly inserted...
par
again tighten the black trip...but no success. wifi signal bar some time flicker..and jump to full signal but all sudden drop.
par
Voir 14 commentaires en plus
Ajouter une réponse
Khurram Shahzad sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 33
Total : 3,553
