Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Mise à niveau de la Nintendo Game Boy Advance, l'Advance SP est sortie, en Amérique du Nord, le 23 mars 2004 avec une structure carrée et un design à coque.
It stays on a white screen after the gameboy advance screen appears
My gameboy usually calls but does not enter the game.
help me
Répondre à cette question J'ai le même problème
Indice 4
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Have you tried cleaning out the game or cartridge slot with some rubbing alcohol? If not, get a cotton swab, soak it in rubbing alcohol and then clean out the pins of the game. Use a good amount on the game then insert it into game slot a few times to clean off the internal pins.
You can also clean off the SP pins with some 600+ wet/dry sand paper and gentle sand them a bit. When you've finished sanding, make sure to clean with rubbing alcohol to remove any dust/particles. This will also remove any difficult grim on them.
Try this out and report back if either of those 2 suggestions work.
Indice 3
3 commentaires:
My friend, thank you for this post. In Jesus name after seeking help with him because i have been trying to fix my sapphire for almost 2 hours earlier, I searched again for different methods on how to fix the same kind of issue and it directed me to this post. I tried it and it worked. thank you so much!
par
this worked for me too!! thank you
par
Do you have to remove any plastic in order to sand the pins?
par
Might need to provide additional information here. Does this happen with GBA games or GB(GBC) games only? A specific game or all types across the board? I know the issue can span from dirty pins and cold solder joints on either system mobo or game cart pcb. Console mobo being the harder repair as you have to trace back and find where the issue is. Currently working on this on a unit myself and occurs only with GBA carts. Calls for the info after Nintendo Logo and stuck on the white screen, doesn't boot the game (which works on plenty of other consoles).
Indice 0
Ajouter une réponse
cezar.maekawa sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 20
30 derniers jours : 134
Total : 19,406
