DC in board testing?
Hi All!
I'm wondering if there's anyway i can test the DC in board to ensure its functioning properly?
I had a liquid spill and since then the light on the ac adaptor is dim and the OS reports "Not charging" - BUT, when left plugged in it does seem to trickle charge.
Edit:
I do get power to the board as it trickle charges. Runs fine from battery. The info i'm looking for is basically what lead on the board can i test for resistance and connectivety to ensure enough paower is pased to the logic board. Unit will NOT run without the battery...I'm assuming there isn't enough power to support the logic board on it's own.
Any direction would be appreciated.
Cheers!
Deleted my answer because links no longer worked
par rj713
Please more infos about the MBP current state. Do you get power to the main board ? Does the machine work when powered only by the battery ? Etc...
par lemerise
anyone have any advice?
par Micco
