So I have an IPhone 7 plus almost 3.5 years old phone and its 295mAh battery is almost dead though it shows 80% battery health remaining but I think its rather only 20% and apple is coding it to prevent it from going below 80 as it'll block peak battery performance.
So coming to the point, I have a bricked iPhone 7 and 6s Plus in my box. I opened them both and found iPhone 6s plus battery is actually bigger than 7plus battery, so I tool battery out of iPhone 7, which is way too smaller. I glued some double sided tape near to battery so that it won't move.
Finally I clicked the start button and guess what, It was drained out so I threw it over the charger for an hour and half.
Clicked On button and my phone came back to life. No bootloop, no lag, no glitch.
Battery health in app menu shows 97% battery health and I have tried playing games over this new battery and a 30minute Pubg Mobile takes about 8-9% battery, So I could now play approx 10games with full charge.
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
8 commentaires
iOS 10 made the iPhone 6s battery crap! As well as iOS 11, I would’ve put my iOS 9 iPhone 6plus battery in my 7 Plus or even 8 plus since it’s bigger and lasts longer! Physically bigger and optimized by the 8 plus , oooooh! Would’ve been amazing! Hopefully it’s software because iPhone 7 Plus battery is worse than the 6 plus! Both software and physically MAH wise
par KyleMile
I put an iphone 7 battery in my iphone 6s successfully too. Had to bend a little the cable connector to fit as described. full capa 2000mAh now! thanks all
par stemcell
How did u bend it exactly because when I bend it the screen doesn’t close due to the cable being raised
par asadali2006
I can’t show the inside of my phone now, but I’ll try to explain: the ribbon must be bent in the form of an S (because it too long). it should be placed at right angle to the lower wall of the housing. In graphic form it looks like this
III - ribbon side view
___ rear wall
/Top view : S /Where ribbon is sitting on the wall
The width of the ribbon should allow the fit. I didn’t have any problem closing the unit. Unless your battery is very fake(?) hope it helps
par Serj
___ rear wall
Top view : S Where ribbon is sitting on the wall
par Serj
Voir 3 commentaires en plus
