Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La Sharp EL-531X est une calculatrice scientifique produite par Sharp.
How can I fix it?
MY calculator won't turn off except after being left alone for a long period of time and the buttons aren't responding. Also it only displays 0=. and I've even tried restarting it many times.
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
1 commentaire
The calculator will display 1 no matter with the battery or not.
It stop working.
par Partager
Ajouter un commentaire
2 Réponses
Solution retenue
Hi,
Try replacing the battery and then resetting the calculator.
The EL-531X uses a LR-44 (or equivalent) battery
Here are two images that show what to do.
Battery Replacement
Reset
(click on images to enlarge for better viewing)
Indice 2
1 commentaire:
Hi. After changing battery and resetting, all the buttons still didn't work. Please help.
par Partager
I had the same problem and managed to fix it by removing the battery and unscrewing and removing the back cover. That's it. I reckon that the issue happened because the "=" key connection was stuck, so uncovering the calculator might have "released" the connection. Hope this helps!
Indice 0
Ajouter une réponse
fahimakhan2 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 50
Total : 5,338
