Aller au contenu principal
Annoncé le 16 Octobre 2014, identifiable par le numéro de modèle A1347 et EMC 2840.
184 questions Voir tout
Adding SSD Drive to PCIe model
Can anyone assist with what parts I would need to add an SSD to a Mac Mini 2014 that came with a PCIe 512 GB drive?
I'd like to make it a dual drive setup, but can't confirm what part is needed to do so. Any help would be greatly appreciated.
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
2 commentaires
me to i would like to recieve and so place a PCIE drive on my mac mini late 2014. can you send me the link for buying that item?
bst regards
par
@yannick17 - Review my answer for the details
par
Ajouter un commentaire
2 Réponses
Solution retenue
If you already have the PCIe SSD then you're adding a SATA drive (either a HD or a SSD) You'll need the to follow this IFIXIT guide Mac mini Late 2014 Hard Drive Cable Replacement and need this part & tool kit: Mac mini Dual Drive Kit. Be careful here! The size of the drive needs to physically fit (12 mm is about it).
If you have a SATA HD already then you'll want this: either the drive carrier with the SSD cable mounted Hard Drive Carrier w/ SSD Flex Cable - Apple P/N 076-00040 or the cable its self Cable, SSD Flex - Apple P/N 076-00018
Here's the IFIXIT guides:
Image Mac mini Dual Drive Kit
Produit
$26.99
Image Mac mini Late 2014 PCIe SSD Cable
Tutoriel
Mac mini Late 2014 PCIe SSD Cable Replacement
Difficulté :
Modérée
15 - 20 minutes
Image Mac mini Late 2014 Hard Drive Cable
Tutoriel
Difficulté :
Modérée
1 hour
Image Mac mini Late 2014 Drive Tray
Tutoriel
Mac mini Late 2014 Drive Tray Replacement
Difficulté :
Modérée
Indice 1
2 commentaires:
Dan, If I already have a fusion drive in there will I need any of these replacement parts, or can I just substitute the respective PCIe and 2.5 inch drives for the existing ones?
par
You'll need to make a full backup before doing anything.
First step is to break the Fusion Drive following this How to split up a Fusion Drive.
And yes, all of the needed hardware sans the replacement drive/s is present.
But before you jump what is your goals here?
par
When adding a HDD to a PCIe SSD only 2014 mini, which HDD cable do you need? (1) the mini dual drive cable, or (2) the upper SATA cable?
Indice 0
Ajouter une réponse
tomtcs sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 1,390
