Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Mavic Pro est un drone compact et pliable avec des capacités vidéo 4K. Il a été lancé en novembre 2016. Le numéro de modèle est M1P et sa manette porte le numéro de modèle GL200A.
Why does my drone get a Jello-effect?
Why does my drone get a Jello-effect ?
I have tried to utdate everything, but nothing seems to make it better.
Blury picture on the phone while filming..
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Solution retenue
That must be from vibration. Most drones that don't have a damper have this problem, but that shouldn't happen with this one. If your under warranty, send it in to DJI so they can have a look at it.
Indice 1
Réponse la plus utile
@pccheese ,Cepeders, Blurry picture on the phone while filming, try a different device as maybe your phone is not linking properly. If under warranty consider using it for replacement/refund/repair. Check to see if the camera/lens is loose on the drone and vibrating around. You may have already done so, do a search( dji mavic pro drone blurry picture) as there is numerous post/articles/forums that discuss this issue. Find below a disassembly guide to get you inside the check for loose wires/components/etc. that could cause an issue. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Vue éclatée du DJI Mavic Pro
Indice 2
Ajouter une réponse
Cepeders sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 13
7 derniers jours : 22
30 derniers jours : 35
All Time: 2,081
