Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Dymo LabelManager 160 is fast, compact and lightweight, making it easy to label just about anything, anywhere. Type quickly on the computer-style QWERTY keyboard, edit with one-touch fast-formatting keys and print for perfect, professional labels every time.
My display is frozen, how do I reset it?
My dymo label manager is stuck on the screen that you use to change the font and size. I've changed the batteries and tried plugging it in but it wont do anything except switch off and on but it just returns to the same screen. Is the a factory reset I can do?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
3 Réponses
Réponse la plus utile
To perform a factory reset:
Switch it off, then press and hold backspace button together with '9' and on/off button
Indice 4
5 commentaires:
Mine will not reset I turn it off. the press backspace '9' and power button. Just turns back on. No Reset.
par
Mine is the same. Have you found a way to reset which works? Thanks
par
I have experienced the same issue it will not reset, and keeps going to the same screen, has anyone got a solution?
par
Tried a power refresh and it still returns to the same screen, no reset works, is there not a manual reset I can do?
par
My Dymo 160 would not do a reset.
1. I took out the 6 screws and removed the keypad from the machine.
2. I cleaned all the gold key points with a alcohol wipe.
3. Cleaned the back of the buttons with the wipe.
4. Dried both parts off with a tissue.
5. Put it all back together.
6. Boot it back up using backspace/9/on&off
7. Confirm the Erase
par
Hi @tim21354
Try a power refresh and check if that resolves the problem.
Switch off the device (if it is on) and then remove the batteries from the device.
Here's the ifixit Dymo LabelManager 160 Batteries Replacement guide that may help.
Press and hold the power button for 30 seconds and then release.
Reinsert the batteries, reassemble the device and check if it turns on OK
Indice 0
1 commentaire:
This still has not resolved the issue, it still returns to the same screen
par
@tim21354 for the LabelManager 160 do a complete reset.
Turn the printer off
important - REMOVE THE TAPE from the printer
Now press and hold "Backspace" button the "9" and the "On/Off" button at the same time
You may need to try this a couple of times due to the awkwardness of pushing those buttons or try the ERASE option by
REMOVE THE TAPE from the printer. then press "9" and "Backspace" simultaneously, THEN the Power button.
That should restore your font options.
Indice 0
Ajouter une réponse
alice sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 22
30 derniers jours : 74
Total : 6,395
