Aller au contenu principal
This iteration of Amazon's Kindle Paperwhite series was released on June 30, 2015. The Kindle Paperwhite 3rd Generation is a 6-inch, 300 PPI reading display tablet that is Wi-Fi capable. The designated model number is DP75SDI.
20 questions Voir tout
Frozen unresponsive screen. Can it be repaired?
Hi!
I have a Kindle Paperwhite, 6" High Resolution Display (300 ppi) with Built-in Light, Wi-Fi - bought in October 2015.
Kept well, it hasn't fallen down, nothing untoward. Stopped working. The screen had an erratic display for a while, and has now stopped responding.
Can anyone help?
Répondre à cette question J'ai le même problème
Indice 4
1 commentaire
I am having the same problem, could you find a solution for this? Please let me know.
par
Ajouter un commentaire
3 Réponses
Réponse la plus utile
I had this problem with an e-reader and it turned out that it quit charging. After placing the e-reader on a new charger it started working again. The models we use in our school are all nooks but this may help you out too.
Indice 1
1 commentaire:
Hey! Thank you so much. But this one is charging. No problems with that. Just that the screen gave an erratic display and then stopped responding. I am trying to understand if it is a screen or motherboard issue. Will try and fix it accordingly.
par
Did you find a solution to this? I am having a similar problem
Indice 0
2 commentaires:
... me too!!!
par
@skeeve205 could you please let me know if you found a solution for this?
par
Try tapping (or knocking with your nail) in the bottom right corner of the front. (Edit: you can also try bringing a magnet to that corner and bringing it away)
If it responds, then I have a workaround for this, that I’ll publish as a “technique” guide within the next few days. (EDIT: here it is!) The only problem with that guide is that it will no longer respond when opening/closing the cover
Indice 0
Ajouter une réponse
Anamika Das sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 12
Total : 4,867
