Why does the screen flash when I try to turn the laptop on?
Sometimes when I press the power button the screen of my dell inspiron 1545 gives a short, bright flash like a strobe light. It's done it a couple of times before but always recovered and managed to boot but this time it's stuck doing it. I took the battery and HDD out and put them back in again, this didn't fix the problem. The LED on the charger is green and everything seems normal with that. The screen will flash with either power source; just battery or just charger
Is there any way to get it back up and running?
2 commentaires
Hi,
Is the display 'normal' when you access the BIOS menu area by pressing F2 on boot?
If so can you boot into 'safe mode' and see if the display is normal as well?
par jayeff
Unfortunately there's no boot whatsoever so I can't access the bios, there's only the strobe flash of the screen. To be honest I think it might be time for a replacement laptop
Thanks for the response
par lipase
