Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La manette sans fil Xbox One modèle 1697 est sortie en 2015 et a remplacé la manette modèle 1537 et a corrigé certains des problèmes trouvés sur ces modèles. La manette modèle 1697 comprend une prise casque intégrée de 3,5 mm, qui la rend compatible avec la plupart des casques tiers sans avoir besoin d'un adaptateur. Cette manette a été abandonnée et remplacée par le modèle 1708.
3.5mm mic not working but can hear others.
I can hear other people but they can't hear me, when I blow or talk into the mic my ring around my profile lights up like I'm talking. I've tested the mic on other devices and works. I've tried other mics but same thing happens. It's a turtle beach headset.
Répondre à cette question J'ai le même problème
Indice 1
6 commentaires
Does it work on other XBOXs?
par
i am having the same problem. i can hear everyone, but no one can hear me. i have tried the cheap one that came with it, the newer one that uses the new port, and a Turtle Beach XO3. i am fearing it is my controller.
par
It's not the controller because I have a brand new controller and headset and still have this problem.
par
So, any answers for this problem?
par
@dtr20 by "Ring around the profile" do you mean you are using this on a PC with discord? If so, I'd check your discord settings first, because if discord talk indicator is lighting that probably means audio is reaching it. If you are not on PC, please explain what you mean in the comments below.
par
Afficher 1 commentaire en plus
Ajouter un commentaire
4 Réponses
Réponse la plus utile
Check your settings to see if your microphone is set to mute or the gain is really low. That should fix your issue as your xbox is definitely picking up audio but is not sending it to people at a high volume.
Indice 1
2 commentaires:
The Xbox is not recognizing that it's even plugged in.
par
Do you have another controller to test your headphones with? You could just be unlucky and got a defective controller.
par
I'm having the same issue. 3.5mm jack, brand new control and turtle beach headsets for the Xbox one. I can hear others, they can't hear me. I'm not muted, all my settings are correct, and others are even hearing themselves but not me.
Indice 0
1 commentaire:
Any answers to this? Really frustrating
par
I’m haveing this problem also
Indice 0
Try going to settings, accessories, and see if your controller needs an update (very weird I know but worked for me with this issue)
Indice 0
Ajouter une réponse
Jake Amato sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 39
30 derniers jours : 154
Total : 24,531
