Aller au contenu principal
Le Sony Xperia Z5 est équipé d'un écran de 5,2 pouces et à 1080 x 1920 pixels, d'un processeur Qualcomm Snapdragon 810, d'une RAM de 3 Go et d'une caméra arrière de 23 MP.
After a water immersion the LCD screen doesn't work
First of all sorry for my bad english...
I put four hours ago my z5 in some water, it was not the first time, after a few minutes the screen died, but the rest of the Phone properly works! The notification Light blink, the touch give vibration feedback, the charging work, all it's working except the LCD screen.
What you suggest to do?
Thanks a lot
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
@fittone, Federico, Stop charging or powering up your device until the liquid damage is addressed correctly, as you could be shorting out components inside the phone. You really should take care of the corrosion that is happening inside the phone from the water damage as that could be your problem. A tear down link for your device Link #1, disassembly guide will enable you to get inside the phone to remove the damage/corrosion caused by the liquid. Use the 2nd link as a guide/instruction on how to clean/repair the device from liquid damage. After this you will be able to power on the phone and see if further damage has to be addressed. Good luck.
Sony Xperia Z5 Teardown
Electronics Water Damage
Indice 4
2 commentaires:
Ehy thanks L Pfaff! I hope to do this asap, but my Phone doesn't was IP certifing for immersions?
par
Don't rely on it as the LCD got liquid damaged.
par
Ajouter une réponse
Federico Fiorentini sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,311
