Aller au contenu principal
L'Asus Transformer Book T100TA est une tablette hybride Windows 8.1 .
76 questions Voir tout
I need a BIOS Rescue password for 2017/06/25
There is a box at start up asking for a password and I didn't set it up. It is my tablet but a "friend" thought it would be nice to have it password protected. Now, they cant remember what they entered. I was able to press ALT + R to get to Enter Rescue Password for 2017/06/25. I found this site http://pastebin.com/L3c3rySj# for reset codes but they don't go as high as today's date.. UGH! I tried and tried to enter a correct password, no go.
Does ANYONE have any ideas? Please? I appreciate any input.
Répondre à cette question J'ai le même problème
Indice 1
16 commentaires
Help I need a key for ASUS rescue 2015/4/10. Tried a bunch I think last four keys are BALA.
par
Help asus 2017/07/07
par
write in the wrong password until it displays a code then post it here noer
par
help please rescue code for ASUS x540 sa 2012/1/13
par
I need the bios resue password for a asus laptop and the date is 2018/03/28 please.
par
Voir 11 commentaires en plus
Ajouter un commentaire
7 Réponses
Réponse la plus utile
Prueba esta, al parecer se repite cada 10 años ABBL9ABB
Indice 2
5 commentaires:
POSTED: 2017/09/28
I need a BIOS Rescue password for 2017/09/28 or anything for a later date within next few days, Please.
There is a box at start up asking for a password which my daughter set up but can't remember what it is. I was able to press ALT + R to get to the screen enter rescue password for 2017/09/28. I found this site for reset codes but they don't go no higher than 2012..... UGH! I tried and tried to enter a correct password, no go. Please someone help.
Does ANYONE have any ideas? Please? I appreciate any help I can get
par
Can anyone help me from 2017/10/02 and days following
par
Use the year 2007.. same day and month
par
If your rescue password year is 2018-04-29, then the password for it will be the same as 2008-04-29 that is what this answer means. That is how it works. The password can be found here https://pastebin.com/L3c3rySj
par
Mine says 2012/01/01 in that link it starts at 2002/01/02 can you help me please
par
Alt+R= 2012/01/06 need your help please. ...Asus pc notebook model T100T....
Indice 2
1 commentaire:
Try this one A2BBAAAL
par
I have the same exact problem but my rescue passwords dated to current so I don't know if this would work but it's worth a try.
Remove CMOS battery and drain all residue power from from the board, hoping that would reset the date settings back.
Indice 1
3 commentaires:
Yes it worked, so I managed to get the date settings back to 2009/01/01 and reset the admin password.
par
I need a rescue password the date of 2018/03/11 because I don't know it
par
How do i factory reset a asus which the model number is D550MAV
par
I need a rescue password for my Asus T100T 2012/01/02 Help please
Indice 1
3 commentaires:
Try this one ALAA4ABA
par
ASUS 2012/04/09 Help me please
par
my asus K53E MFD: 2012-02
i need a recue pasword
par
Indice 0
just in case it serves others :
get your Bios date from the POST screen or use free tools like speccy to get it, or type "systeminfo" at the command line prompt and check the results for the BIOS part (bios vendor and bios date).
If you can use windows, set the system date to your bios date, at a time inside the day (say 00:00:00 or 12:00 AM for example). Now reboot and press F2 to access BIOS.
Enter directly your password derived from your Bios date as stated here : https://pastebin.com/L3c3rySj
Note some PCs require to enter a wrong password first then the display changes from "password" to "rescue password".
Enter your password as you would on a QWERTY keyboard : it means for example that
1-9 &0 are on the 2nd row under F1-F11 without pressing shift,
3rd row begins with Tab,QWERTY
4th row letters begin with ASDFGHJKL
5th row letters begin ZXCVBNM
When password is OK, the current date being the BIOS date, BIOS panel opens.
Then go to "security" menu and set an empty password for Administrator an user.
Returned message should read "password uninstalled" or something similar.
Next time , F2 will not ask for anything if Admin password was correctly blanked out.
This worked for me for an ASUS X73S having a BIOS date somewhere in january 2009.
Hope it helps any further reader to get some old ASUS back to use.
Indice 0
sadly, none of the methods have worked, and i've been very thorough...only way now is David Zou's method or manage to flash them with..maybe Kiosk? whatever method works will require obliterating the password lock...
Indice 0
Ajouter une réponse
Diana Jones sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 22
Total : 21,417
