Why is one channel of my headphones not working?
One of the speakers on my B&W P5 headphones is not working. How can I fix this?
First you have to find the where the problem is located. To do that use a multimeter to narrow done the offending line break or component break. This guide amy help you determine that: Bowers and Wilkins P5 Headphones Audio Cable Replacement
Thanks. I don't know what a multimeter is but will look for one.
See above image link for multimeter.
Thanks. What is next after I have the multimeter?
i have the same problem, an ui use the multimeter and in the offending side isnot showing any numbers, any solution to this?
Octante you need to locate the break in the wire before you can fix it.
i have the same problem, an i use the multimeter and in the offending side is not showing any numbers, any solution to this?
Dernières 24 heures : 2
7 derniers jours : 16
30 derniers jours : 69
Total : 6,858
