It will run then it will stall and sputter
The club car will run for a short stint then stall and sputter. Let sit a few minutes it will run again for a short stint.
Check gas cap vent, sounds like it may be starving out.
Here's a good video on a small gas motor and the difference venting can make:
Thanks. Was a good idea to try. But that's not it.
Tryed it didnt work
My club car precident is doing the same thing please help
Check to see if your coil is getting a good flow of air around it. Mine was covered, no buried in dirt and grass which allowed it to over heat. After a few mins it would run fine for a few more mins. It is not super easy to get at the coil, so you may want to consider having another one on hand. Good luck.
Dernières 24 heures : 1
7 derniers jours : 23
30 derniers jours : 128
Total : 11,028
3 commentaires
tksutherlin sounds like fuel supply issues. What exact model is your cart? what have you checked?
par oldturkey03
I to am haveing the same problem when first starts up runs really good for about 2 minutes then spits and spudders ive put new fuel pump new filter lines carb no water in fuel nothing like that thin i can cut it off and let it set for a little bit and start it back up and it runs grate and does it all over again
par William Moore
Sounds like a bad coil my cart had the same problem after changing the coil it fixed the problem. It was a pain to change out takes about 2 to 3 hrs.
par Kevin Jones
