Correct glue for replacement screen?
I'm replacing my Google Pixel screen, and Amazon recommended I get "Eco-Fused adhesive sticker tape, 2mm". The tape works alright, it took a little bit of layering for a few recessed areas. The first time, the bottom of my screen wouldn't stay in for longer than 30 seconds. Long story short and 4 revisions later, I've gotten the screen to remain fully attached... mostly. The bottom and sides still sit 1/2 to 1/4 of a millimeter above the case edge (was flush with the factory screen), and I know it could be doing better because I can press soon the screen and it will squish back into complete compliance for another minute or so.
As it is now, the screen is functional and the phone has spent a full night in between the bottom of my mattress and my bed slats. Since heating the phone is necessary for removing a screen, does this eco-fused tape need to be heated as well after being applied in order to stick fully and firmly? Should I be using a different adhesive? Since I don't own a heat gun OR a hair dryer... Would the oven work, set to 175 F°?
2 commentaires
What sizes do you guys recommend? 2mm only?
par Guilherme Salomão
Can you use Krazy glue to glue a new screen on your phone
par william Lundy-sarnowski
