Aller au contenu principal
Pour réparer ensemble - Je crée un compte
A1706 / EMC 3071 – sorti en novembre 2016, ce MacBook Pro 13" présente le Touch Bar avec écran OLED. Il inclut un processeur Intel Core i5 dual-core "Skylake" et quatre ports Thunderbolt 3.
How to Repair the black strip that says MacBook Pro
Hi I noticed something got stuck in the crack where the screen folds down. Now I have a pressure crack/ hole. can that plastic strip be replaced instead of replacing the whole screen etc..
Thanks
Julie
Répondre à cette question J'ai le même problème
Indice 3
3 commentaires
Have you repaired it? I have the same problem, happened today
par
It can be replaced. I have seen these parts available.
par
Where can you buy the parts? I have the same issue with my 13" Macbook Air too
par
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Yes the chin plate can be replaced! Here’s the part: Chin Plate and here’s a guide that can help you see what’s behind it MacBook Pro 15" Touch Bar 2017 Replace LOGO Baffle on the screen,替换屏幕底部LOGO挡板 Replacement
Indice 1
Yes, it is possible to replace the black strip at the bottom! I’ve actually done it a few days ago and it’s fairly simple. First you need to have a source of heat and heat the bottom strip as it has adhesive on it to keep it stuck down. Once you’ve heated it a bit you need to find something to pry the strip up. You can use anything that’s thin enough to fit into the side of the strip to pull it up. I suggest starting from the corner as under the strip are a few ribbon cables for the display so be very careful! Once you’ve got one corner up just make sure to heat it up as you go along to make it a lot easier. Once you’ve got it completely off make sure you take out any remaining pieces or shards from the old strip. Then you’ll be good to place down your replacement! I hope these instructions were descriptive enough to guide you through the process :)!
Indice 0
1 commentaire:
Oh man is this an old post. I just checked the date of when it was posted.
par
Ajouter une réponse
swimmer35 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 24
Total : 3,211
