Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Commercialisé en janvier 2015, le portable XPS 13 se veut un concurrent du MacBook Air, avec un "écran sans bordures " et une option de mise à niveau à écran tactile.
9360 battery in 9350 model
Does anyone know if the 60kwh battery from the 9360 xps 13 will fit in the chassis of the 9350 xps 13? I know that the original 9350 battery was only 56kwh but since I need to change the battery I figured I would use the larger battery if it fit.
Répondre à cette question J'ai le même problème
Indice 3
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Yes it will work same battery size for the chassis
Indice 2
6 commentaires:
Would you also know of any possibilities to upgrade battery in XPS 9343 model?
par
Hello there, I purchased the Battery of the Model 9360 for my 9350 model. It fits fine, it really has the same size, but the bios cannot identify the battery. The Notebook runs fine but I guess the communication ports are positioned diefferently. Anyone has a solution to it? I am not sure if just the connection cable hase a difrent configuration
par
Hello, I did the same as you Claudius and same problem! Did you find a solution?
par
It's not a problem of communication port, it's just because the laptop detect it's not the original battery and refuse to charge it. First it worked for me until the battery was empty and then the laptop refused to charge it
par
Is there a hack to getting this to work yet?
par
Afficher 1 commentaire en plus
you need the exact oem model battery for the xps laptops or it wont charge. the front led indicator will flash amber and white if its not the right battery
Indice 0
Ajouter une réponse
Online Sales sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 22
Total : 2,715
