Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Why does my navibot dont switch on?the battery is charged, but no ligh
My navibot Doesn't switch on. The Battery is charged but all lights are off. I tried to Clean it but Nothing changes.
Répondre à cette question J'ai le même problème
Indice 3
1 commentaire
erro c01 alguém tem esse problema obrigado.
par
Ajouter un commentaire
3 Réponses
Réponse la plus utile
@doxdici you will have to disassemble it and take a look at all connectors and check the battery to ensure it is working. A dead battery may appear to be charged but does not hold a charge. Start off with this teardown Samsung NaviBot SR8855 and take some pictures of what you encounter. Post those with your question so that we can see what you see. Use this guide Ajout d'images à une question existante for that.
Use this diagram
to follow the power flow and see if there are any obvious damaged components etc..
Indice 1
1 commentaire:
Where did you get this schematic?
par
Your battery is not recognized by device it doesnt turn it self. You need to check battery 14.4-15.5 volt between
Indice 0
2 commentaires:
Same probleme here, battery ok but navibot death, no lights, notting....! Switch is ok, voltage on the cirquit bord ok.
par
Are you sure with battery voltage? My battery shows 13.3 V and It`s new...
par
90% switch on/off, it was very dirty contacts inside, you should change switch
Indice 0
Ajouter une réponse
Doxdici sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 15
Total : 3,853
