Windows wil not install from hdd or reboot disks.
I have had my laptop for approx. 8 years. I keep most things back up so when ever I have problems I always just reinstall Windows.
Now Windows will not reinstall either from my hdd or boot disks. The reinstall process form both is running much slower then usual and it never completes. Form the hdd it says failed and from AI RECOVERY RESTORE it usually gets to around 22% and gives up.
I have a sneaky suspicion that my hdd might need replacing, can anyone offer any help?
Thank you.
Indice
0
Did you make recovery disks? It sounds like either your hard drive is failing, specifically the partition where the recovery information is. It sounds like you did make disks, so I would suggest looking to either a replacement SSD or fusion hard drive.
par S W
Hi @max1981 ,
Go to the HDD manufacturer's website and check if they offer HDD diagnostic tools for download to a bootable disc. e.g. Seagate will boot into DOS and check the HDD if it is a Seagate model
par jayeff
