Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Commercialisé en ligne le 16 janvier 2009, l'Inspiron 1545 est un ordinateur portable économique de 15,6 pouces disponible avec 3 ou 4 Go de RAM. Il a succédé à l'Inspiron 1525.
My laptop repeatedly shutdowns after I power it on.
when i switch on the laptop after a couple of days then it works fine for about 15-20 minutes, after that it shutdowns. when i again switch on the laptop it again shutdowns during booting within 15-20 seconds, and continues to shut down again and again.. It only works fine for 15-20 minutes, when it switch it on after quite a time.
anyone, please help, as my that laptop has became completely useless.
Répondre à cette question J'ai le même problème
Indice 1
8 commentaires:
Alright, first things first. Can you try reseating the RAM DIMMs inside the machine. Also, make sure that the system is hot overheating. Can you hear the fan spinning up? Can you feel hot/ warm air coming out f the vent?
par
To me it seems like there is unstable power delivery so i would try to reseat the battery in case the connection is loose, also did you have the laptop on charge at the time?
par
thanks for your replies guys, I will like to add that I had tested switching on the laptop without battery also, then also there was the same problem of quick shutdown , it doesn't seem to be any software problem though.
par
hi Alex, I will like to add that i can not hear fan noise or can not feel hot air coming out from the vent,..
par
hi Adam, power connection is not loose, as the shutdowns follow a serious pattern, when I switch on the laptop after quite a time then it runs fine for 15-20 minutes, and after that it shutdowns, again at the same time when i switch on the laptop it shutdowns in about 20 seconds, and again and again in about 20 seconds.. when i leave it for a quite a time then again the same pattern repeats,..20 min-20 sec-20 sec-........
par
Voir 3 commentaires en plus
Ajouter un commentaire
2 Réponses
Have you tested your battery and your power cord? They are notorious on Dells for crapping out. Sounds like it not getting enough amps to charge the battery or the battery cells are about done. I would start there and then move to software related diagnostics.
Indice 0
1 commentaire:
thanks for your reply, I will like to add that I had tested switching on the laptop without battery also, then also there was the same problem of quick shutdown , it doesn't seem to be any software problem though.
par
When it cools down , you can you use for 15-20 minutes , the Processor will send signal to Protection circuit to shutdown when it reach the maximum tolerance of over heating, it means you have a defective cooling system, e.g., Fan is stuck-up or full of dust and can't rotate, try cleaning it or replace with new one, I encountered hundreds of cases like this. just give a try. good luck
Indice 0
Ajouter une réponse
Amit Raj sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 526
