Aller au contenu principal
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
382 questions Voir tout
I hear the fan louder
Hi, i have a mid 2010 27"core i7 iMac and although all these years i thought it was fanless, the last few days im noticing that -actually- there is a fan :-) It's not like its making a huge noise, i can only hear it but even so it seem strange because i hadn't noticed it before.
Could it be failing? Before i open the iMac to inspect, can i check it through software perhaps?
Update (10/15/2017)
Does this help in some way?
Répondre à cette question J'ai le même problème
Indice 0
3 commentaires
Did you change the hard drive?
par
Yes @mayer i did change the drive, why?
par
Sorry for mixing you @mayer, i meant i've added an extra drive, an SSD drive.
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
When you chang the hard drive you have to address the Apple priority heat sensor or you will get a run away fan. OWC makes a thermal sensor that you need to install to stop this. Here it is:
https://eshop.macsales.com/item/OWC/DIDI...
Indice 2
25 commentaires:
What exactly do you mean by "run away fan"? Please describe clearer the issue ;-)
par
The system will go into Safe mode (ramping up the fan to max) when it looses access to any of the thermal detectors within the system.
In this case the Apple custom OEM HD you had in your system offered the needed input, but when you switched out the drive the new drive does not offer that input. Thats why you need the OWC in-line sensor to replace the missing sensor.
par
I see but i have both the Original HDD and the SSD installed!
par
Please tell us with drives you changed
par
I havent changed any drives (sorry for mixing you up before), i only installed an SSD to the original configuration ;-)
par
Voir 20 commentaires en plus
Ajouter une réponse
genik sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 7
Total : 307
