Aller au contenu principal
A Turbosteam iron by Morphy Richards.
Questions au sujet de 13 Voir tout
Why is there no power to the iron. No indicator light on.
Whilst ironing the power light went off and iron stop working.
Répondre à cette question J'ai le même problème
Indice 5
3 commentaires
I have lefty iron forgot to turn off just noticed but the iron is off and now won't work
par
I’ve a steam iron generator it’s stopped workin the light doesn’t come on no heat nothing can u help?
par
My iron won’t switch on .. change the fuse
par
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Many of the UK heating devices have a fuse within the plug. Carefully open the plug to gain access to the fuse. Here's an image of the plug assembly from the Morphy Richards Iron Teardown:
While not stated you'll see the far left & right connectors are also the fuse clips. With an Ohm or continuity tester you should see these are connected (with a fuse in place), If not you need a new fuse.
Indice 3
1. check the cord
2. there is a fuse in the steam iron press, get it replaced by service centre.
4. Thermostat is not working.
4. heating rod is damage.
Indice 1
1 commentaire:
Where can I get my iron seen to ? Rescaled it now won’t come on just keeps going off checked fuse new fuse in but still not coming on !
par
Ajouter une réponse
Mornay Fourie sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 43
30 derniers jours : 292
Total : 23,525
