Kurt,
I am hoping you are still following this - so here is an update on the Evolve 75 - which is what you have on the photo.
Do NOT follow the evolve 65 instructions - I did and broke one of the tabs.
Instead on the OPPOSITE side from the one you are showing on the photo you will notice a small Torx t5 screw.
Unscrew that one, and one that side will popup. The opposite side comes off by lifting up the orange speaker holder slowly to around 30 degrees and it simply unhooks. the speaker wires are very tiny so don’t pull too hard.
the rest of the stuff is held in place with Torx t6 self tapping screws into plastic, INCLUDING the back cover. once you take those off you have access to all boards and wires. -
so that is how to open them up.
Downside - my microphone still does not work, so I suspect I may have broken links from the microswitch to the board - it has a tiny printed links on a tiny capton tape so I may simply solder the microphone directly and mute and unmute with the buttons instead of the boom
Hope this helps - bot sure when I can get some photos - But with the approach above it took me all of 5 minutes to open the boom side of the headset. the other side should be just as easy -and that side is the one with the battery. there is a youtube video on how to replace the battery on Evolve 75 -which is where i got the information on the torx t5 - credits where credit is due.
A voté
Annuler
Indice
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
2 commentaires
do you know if it is possible to put off the mic in order to put on a new one ? .... my dog has broken the mic (seems very good :-))) Now, I can hear, but I can't speak. Thanks (please use easy vocabular, I'm french)
par a.morisseau
I know this is an old post, but does anyone know how to disassemble the Jabra Engage 65 base unit? One of the UBS ports appears to have com disconnected from the internal circuit board. When the cable is plugged in, there is up and down movement and it will intermittently connect (PC recognizes the unit). Fortunately, there are 2 USB ports and one still works,
I can see two screws directly behind the display section, but removing them doesn't seem to be enough. It is possible that there are concealed screws underneath.
par MaxR
