Aller au contenu principal
Sorti le 25 septembre 2015. Modèle A1688/A1633. La réparation de ce modèle est similaire à celle des versions précédentes et nécessite tournevis et outils pour faire levier. Disponible en GSM et CDMA / 16, 64 ou 128 Go / Argent, Or, Gris sidéral ou Or rosé.
2692 questions Voir tout
Why does it keep logging out (has over 50% battery charge)
Hi all,
I recently changed the battery on my iphone 6s using the ifixit kit, followed the instructions. The only thing I didn't do was remove the screen entirely, had it propped up at 90 degree angle while I replaced the battery. I also found that the battery connector wasn't so flat, I pressed it down and screwed it in.
The first 2 days it was fine but today after a full charge it logs me out when I'm on it for a about 1min. Then I need to log in again either password or touch id and it goes to home screen not to what I was doing before. For example I'm on the internet then then loading wheel appears, goes black and then then the log in screen appears, then I'm back to homescreen.
Help? What might be wrong?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Loading screen means the phone is being told to turn off, probably due to the phone thinking the battery is too low (flat battery).
I would assume the replacement battery is faulty.
A recent iOS update also has caused issues with the phone soft-rebooting itself if the date and time was not set manually, this may or may not be related to your issue.
Indice 0
Ajouter une réponse
Sylvia sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 2
Total : 71
