Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Version plus petite de l'iPad Pro original. Sortie le 31 mars 2016. Dispose d'un écran de 9,7", d'un processeur A9X et d'options de stockage de 32, 128 ou 256 Go. Disponible en argent, gris sidéral, or et or rose.
Power button/volume buttons not working after screen replacement.
After successfully replacing an iPad Pro 9.7" screen with no issues there power button/volume buttons do not work. These are different flex cables so this tells me something with the screen is potentially preventing the functions. I have disabled sleep/wake feature but this does not resolve the issue.
Also, oddly enough with the accessibility on the on screen power button and volume buttons will not work either. I have reconnected the old screen to see if it was a screen issue but the buttons still do not work. The power button will turn on the iPad initially as well as wake the screen but it will not put the iPad to sleep nor will it prompt a power off if held down. Any help/suggestions?
The battery was disconnected prior to any other cables were disconnect and physical everything in the device is clean and connectors inspected.
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
Ajouter un commentaire
2 Réponses
Solution retenue
I wonder if you have found a resolution to this issue. Based on what you say, you have tried the most obvious things. I would try a Hard Reset and if data retention is not an issue, a full restore.
Indice 3
3 commentaires:
Hey thanks for the response. I actually got everything working again, it seems to have been a software issue after the screen install for some reason. I did a data backup through iTunes, restored in DFU mode and then set up the iPad again. Power button and volume buttons worked again right away and his been working good for a few days now!
par
Awesome!!
par
I'm thinking all you might had to do is hard reset and it would of worked but great it's working
par
Thank you DC Tech for responding with your solution. I had the same problem with an ipad mini 2 with ios 11. All i had to do was plug the ipad into itunes and as soon as itunes recognized the ipad the problem was fixed.
Indice 1
Ajouter une réponse
DC Tech sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 20
Total : 8,701
