How do I by pass my Frp lock
How do i by pass my Frp lock on my galaxy s7 edge
You need to flash the unit utilizing Odin. It's Factory Reset Protection, so the only way to override it is flashing.
You need a windows pc, Odin Software, and the flash file for your unit. I believe the file you're going to be looking for is for SM-935F. You can verify this on that lock screen, if not put it to download mode and it will tell you the unit type.
Entering Odin Mode on Samsung:
Hold Side key, Vol Down, and home button. Screen will jump to Odin/Download mode.
Good Luck
Model number is never displayed on the lock screen.
Checked one, says it on 2nd line. "product name"
Info on how to bypass FRP here:
http://forum.gsmhosting.com/vbb/f777/uni...
Requires factory resetting the phone which user data is wiped and downgrading the phone to 6.x.
If you have a Z3X flashing box or something similar to that you can skip all the steps and use the one click FRP unlock that way.
Just follow this video step by step and you can bypass your frp lock on galaxy edge 7 easily
There are many ways to bypass frp lock but if you searching for latest video tutorial so here it is follow video step by step
There is an app for samsung phones called TEST DPC. It lets you run the phone by owner or administrator. It works very well. Free also.
I found how to do it.
Flash old firmware, then reboot to the menu where i can reset factory default… RebbotReboot and then i was able to enter my account there.
So we need to play with old firmware, than old power and volume to go in the menu where we can access the Android Factory default menu.
Hi. Here are a video https://www.youtube.com/watch?v=r5vVos4e... “How do I by pass my Frp lock”
To See this video, you can easily understand how do i pass my frp lock.
You can use a few tools to bypass FRP lock, but to mention, in particular, DroidKit is capable of removing FRP lock.
All Samsung Galaxy Direct FRP Unlock || Android 9/10/11/12 || No Backup || Samsung A8 2018 FRP
You can bypass it https://mp3juice1s.cc/
I bypass that. I use some course hero codes in that tool. I get that at https://thetechbytes.net/unblur-course-h...
There are many tutorials online that teach how to bypass FRP lock but if you are looking to unblur course hero, you can check that here https://www.enttechub.com/2022/02/course.... Well, there are apps at https://theladmods.com you can use to bypass FRP lock too.
To do this you must have frp bypass app. If you have not then you can get from here: https://apkvow.com/frp-bypass-apk/com-fr...
YouTube, no software or computer required. Quick search and you’ll find what you want. I’ve done loads that way.
Download app called TEST DPC , it resets it completely. Restarts and ask if you want to be device owner. It works, I just unlocked my samsung j7 with that app. How to download it to your device is turn on accessabilty moood, go to settings under talk back settings then go to android setting up switch, it will show youtube, then go to settings in youtube. Go to privacy for youtube. It will take you to internet. Then just type in test dpc. Download the app. Open and set up.
Thanks for the information. Much appreciated.
In fact, Google account and Google password is the quickest and effective method to bypass FRP lock on Samsung, ask the owner or the seller to provide the Google account, the ODIN software is complex to remove FRP lock on Samsung, and it’s too professional to operate.
The newest and easiest method to remove FRP lock on Samsung is the tool-Eelphone Google Account Removal, just several clicks during the whole process.
Dernières 24 heures : 4
7 derniers jours : 8
30 derniers jours : 73
Total : 51,391
14 commentaires
Has anyone tried it lately? I have also the model SM-935F and I tried to flash it with Odin and the newest firmware. But it didnt work. Has any one an idea how to bypass the FRP?
par Mustafa
use https://youtubewala.com forum to fix the issue
par Easy Health
Using the FRP tool (https://minerev.com/frp-bypass/), you can easily bypass the FRP lock.
par Maya Ruby
I think using vROM ByPass APK will help. Get one from here (https://clashmod.net/vnrom-bypass-apk/)
par God Yato
You can bypass any phone location using the bypass apk: https://youtech.ooo/frp-bypass-apk/
par Jhon Carter
Voir 9 commentaires en plus
