Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Informations sur la machine à café à dosettes de Phillips sortie en 2006.
My Senseo is just model 7810, no other numbers or letters.
I am trying to remove the boiler to get at the switches but none of the dozens of sites on You Tube show my model or the way the boiler is attached. The only fastener on mine is what appears to be a little clip on the top of the boiler but I see no way of “unclipping” it.
Help.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Solution retenue
No, this is not the way mine is held in. There are none of those clips on mine, just a wedge shaped catch on the top of the plastic boiler. It looks like you should be able to spring in loose with a screwdriver but there is a web of plastic in the center of the wedge that prevents that. I pulled on the boiler pretty hard but it won’ t come out and I don’t want to break anything.
Indice 0
Réponse la plus utile
Hi @abbypumpkin ,
Looking at this ifixit guide the "clip" above the boiler is actually a type of nylon cable tie that needs to be cut with scissors or a sharp blade for it to be removed. See Step.5 in the guide. Perhaps yours is the same
(click on image to enlarge for better viewing)
Indice 2
2 commentaires:
I have tried to put a picture of my problem on here but the site does not appear to allow that.
par
Hi @abbypumpkin ,
You can't add images to a comment but you can add them to your existing answer or put them in a 'new answer' to the question and because you have answered before you will get the option to either submit as a new answer or as an update to your existing answer
Here's how Ajout d'images à une réponse existante
par
Ajouter une réponse
George Moore sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 17
Total : 649
