Aller au contenu principal
An Android 4.4 smartphone released in August 2014.
108 questions Voir tout
"internal storage running out.
I keep getting the message "internal storage running out.please free up some space." But I can't free up space because the message keeps coming up.
Répondre à cette question J'ai le même problème
Indice 3
6 commentaires
I would try restarting the phone and see if that will keep the message closed long enough for you to free up some space.
If that doesn't work, you can plug your phone into a computer using the usb charging cable, and access the phones hard drive from the computer. From here you could manually delete/ move files around to free up some space. Plus anything you want to remove but still keep, you can just copy the files to your computer then delete them on the phone. Most likely your larger and easiest files to move around will be in your DCIM and or Download folder.
par
Hi @drsuesst20 ,
Just be careful which files you move/delete etc. as you could remove important system files which may make your phone initially inoperable. As @usmiljtw28 said stick to the DCIM and Download folders,
Also have you got a SD Card inserted in the phone? You could move your pictures and perhaps some apps to free up internal storage space. (not all apps can be moved to SD card)
par
I did all of the above cleared whatever I needed to transferred DCIM etc. to a 32 gig SD card. When I checked the File manager its says I have 85+ MB of 4 GB internal shared storage available yet the message “internal space running out” keeps popping up. It is very irritating.
par
how do i get rid of some apps that were already on the phone its taking up my storage
par
# How can I free up space on my Blu 5.0 phone
par
Afficher 1 commentaire en plus
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi @ Lisa Wilson,
Can only speculate that as you only have 2% internal storage left available (85MB out of 4000MB - or 4GB) that is the reason for the message.
Did you try moving the apps that can be moved to the SD Card, to try and clear some storage space in the internal memory?
Be aware that not all apps can be moved to the SD card. This depends on whether the app developer has enabled this setting when the app was first created.
Indice 1
Ajouter une réponse
john sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 3,625
