Aller au contenu principal
Gaming laptop released in 2014 with an Nvidia 860M graphics card and a 15.6" display. Updated in 2015 with 960M graphics.
20 questions Voir tout
The Hard disk is not detected?
My computer won't boot up, I get an error message that says "EFI Network 0 for IPv4(6) (F0-76-1C-1E-ED-AB) boot failed" and when I go to the setup utility it said "Hard disk [Not Dectected]". Any Advice?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Hi,
Can you hear the HDD spin up when you start the laptop? If not and even if you can, then the HDD may have failed and will have to be replaced.
Here is a link to service manual for your laptop. Scroll to p.39 to view the necessary pre-requisite steps and then the procedure to remove the HDD.
Use this to initially check that the HDD is firmly connected.
If it is, you can try and re-seat the HDD and see if this solves the problem, (remove and re-insert the HDD).
If this doesn't work then you could remove the HDD and install it in a desktop computer and check if it is recognized and works there.
If it does then there is a problem with the motherboard in the laptop.
If it doesn't then the problem is with the HDD.
Indice 2
1 commentaire:
I know for my laptop, the HDD was not installed properly and 2 screws were missing. After reinstalling it, it worked
par
Ajouter une réponse
amandasmall13 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 5
Total : 10,186
