blue tooth driver missing I think?
blue tooth is not working or showing in manager device. but blue tooth light comes on is all i get . if i turn off the blue tooth on the SCM it will not toggle back on until a restart is done .
2 commentaires
Hi @cajun70582 ,
Have you tried enabling the 'Show Hidden Devices" (in the View tab) in Device Manager just in case it is listed there?
Also check if there is an 'Other Devices' list entry in case it is in there.
Apologies if you have already done these things.
When did it stop working?
Was there an OS update around about the same time that it stopped working?
Have you got a restore point that you can go back to to see if you can make it work this way?
par jayeff
Hi Jayeff
yes when enabling the Show Hidden Devices it is listed their . I am not aware of exactly when it stopped working .
Strange thing is it started working again on its own then hours later it stopped working again , also when it was working it was visible and not in the hidden devices .
par tony d
