Aller au contenu principal
Pour réparer ensemble - Je crée un compte
L'enregistreur à microcassettes Sony M-430 permet d'enregistrer et de lire de l'audio. L'enregistrement par simple pression, les deux vitesses d'enregistrement/lecture et l'arrêt automatique en font l'appareil idéal pour enregistrer en déplacement. Numéro de modèle M430.
Can I fix the speakers in my Sony m 430 microcassette corder?
I barely found this sony m-430 microcassette-corder and it works for the most part except the sound quality. When I play back anything I’ve recorded it’s mostly just faded voices with an overpowering static sound. Anyone know what I can do? Or is it time to give up? Thank you!
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Hi,
Try cleaning the pickup head and see if this improves the audio quality.
Use a Q-Tip moistened with IPA 90%+ (Isopropyl Alcohol - available at most pharmacies).
It may also be a microphone problem but you would need to do testing of the circuit to try and find out where the noise was emanating from to prove this was the case.
Here is a link to the ifixit Changement microphone Sony M-430 Microcassette-Corder guide. As the microphone is a sealed unit it most probably cannot be repaired and would have to be replaced if it was the cause of the problem.
Indice 1
1 commentaire:
thank you so much for the help!
par
Ajouter une réponse
Melissa Castro sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 21
Total : 619
