Aller au contenu principal
Comment réparer son MacBook Pro 13" Unibody, modèle mi-2012, A1278, processeur 2,5 GHz i5 ou 2,9 GHz i7.
1624 questions Voir tout
Battery will not charge and MacBook will not run when plugged in
I had a major liquid incident on my late 2012 Unibody MacBook Pro. The good news is I replaced the logic board and the battery and everything was working well. That was until I realized the battery was not charging. When I select the indicator light on the side of the battery is flashes green rapidly. When the power cord is plugged into the MAC its stays a constant green and the MAC will not power on. Now that the battery is dead, the MAC will not power on at all.
I have checked all connectors and still no luck.
Anyone have any ideas?
Thanks
Megan
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
One other note, I have tried an SMC reset with no luck at this point. The light on the MagSafe adapter does not change. The green light on the MagSafe adapater is also dim.
par
Ajouter un commentaire
1 Réponse
Solution retenue
Since you've already replaced the logic board, I'd replace the DC-In Board next:
Remplacement de la carte de raccordement MacBook Pro 13" Unibody mi-2012
Indice 4
1 commentaire:
I finally got to chance to install this and it worked. The only thing not working after all of these replacements is now the keyboard. Bummer!
par
Ajouter une réponse
Megan Heinz sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 1
Total : 78
