Aller au contenu principal
La version Wi-Fi de l'iPad Air d'Apple, numéro de modèle A1474. Disponible en gris sidéral ou argent, il emploie le processeur A7 personnalisé et est livré dans des configurations 16, 32, 64 et 128 Go.
20 questions Voir tout
Ipad Air A1474 has backlight but no image
Ipad Air A1474 has backlight but no image.
The tablet is turned on, there is sound, the backlight is visible, but there is no picture.
This happened after changing the digitizer and I guess the reason is that I did not isolate the battery before.
I found a missing component near the lcd screen connector. I'm not sure if it's relevant to the problem?
Please, help me :(
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
4 Réponses
Solution retenue
The missing component is C7046 (0.1uF / 6.3V / 20% / 01005 / X5R). This capacitor is "inline" and used to filter the EDP_DATA_N<2> line and as such, it has to be replaced.
Such small components are difficult to DIY repair so your best bet is to find a repair shop that does micro-soldering repairs.
Indice 5
6 commentaires:
Thanks for the quick response!
Is the absence of this capacitor causing no image, only backlight?
par
I think this is not the missing component because the missing component is between the two sockets J7000 and J6620.
C7046 you mention is on the outside of the J7000 ?
par
It doesn't show on the schematics available in the wild but it does show up in ZXW Tools.
par
Thanks for the response !
par
Thank you very much, it helped me a lot.
par
Afficher 1 commentaire en plus
can not find this component on the schematics?
Indice 1
1 commentaire:
I need the electric scheme of the ipad A 1474 can help me
par
Good afternoon I'm in need of an information I'm having a problem on the capacitor c7046 of the ipad air model A 1474 I need the value of this component, can you help me.
Indice 0
2 commentaires:
Good afternoon I need the electric scheme of the ipad air model A1474 can help me
par
Try simple things first like hard reset, put off battery press power button for 20sec, install battery again and try to turn on the device. If problem exist then seems you made a mother board damage, maybe you removed a small part like capacitor or filter. You need to see schematic and compare with your motherbowrd
Indice 0
Ajouter une réponse
George sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 4,008
