Ethernet connection is not being recognized.
I am trying to use an Ethernet connection instead of WiFi for faster speeds but when I plug the cable in nothing happens. Ethernet 1 disappeared from device manager and only the WiFi adapter and my VirtualBox Host-Only Ethernet Adapter shows up. I have a Intel WiFi card installed. Windows Diag. doesnt find a problem. It is not disabled in the BIOS and it it not hidden in device manager. It previously worked. Runs Windows 10 Home Edition Insider Preview Build 1703
Model E5-573G
2 commentaires
Hi,
What is the model number of your laptop?
Have you checked in Device Manager > hidden devices to check if it is listed there for some reason (click on View tab in DM and select Show Hidden devices.
Is there a listing for "Other Devices" in DM where it might be located?
Have you checked in BIOS to see if there is an option to enable/disable the LAN adapter?
par jayeff
Hi,
Has it worked before when using Win 10?
Did you check for any LAN enable /disable in BIOS? You didn't say.
Have you tried the Windows troubleshooter to see if it can fix it for you?
What happens if you start in safe mode "with networking"? Can you use the LAN adapter?
par jayeff
