Aller au contenu principal
Pour réparer ensemble - Je crée un compte
The Samsung Galaxy Tablet E 9.6 was announced June, 2015 and released on July 2015.
weak wifi signal and dropping
im having problems with wifi on a tab e that i have replaced the digitiser connector on, its a very weak signal around 1 bar but sometimes none and drops out. the router is about 2 metres away. another samsung tab connects fine my a3 connects fine, just a problem with this 1. it has been reset but still nothing. any ideas
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
3 Réponses
can your bluetooth connect to any of the devices?
the tablet uses different antennas for pickups, but the same chipset for processing the signals. so if your bluetooth is failing as well, you will be looking at a board level issue, and if your Bluetooth works, then you have an antenna failure.
Indice 0
3 commentaires:
yea bluetooth is working
par
think i found the problem a pin has been broken off
par
welp, then i guess repairing that is your first step!
par
Hi. Same exact thing happened to me. After replancing digitizer, Wifi got wonky. Bluetooth working fine. But I don't know where the wifi cable/flex/pins (or whatever) are so I can check . Can you show/tell me? Thank you.
Indice 0
There is a chance that the WiFi antenna was damaged during the replacement. The antenna is located in the top right corner of the housing, right by where a pry tool will go for removal. Try having whoever replaced your screen replace that as well, because that repair person is at fault here.
Indice 0
1 commentaire:
Sounds like she replaced it
par
Ajouter une réponse
daniel sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 23
Total : 2,618
