Aller au contenu principal
Pour réparer ensemble - Je crée un compte
A1706 / EMC 3071—Sorti en novembre 2016, ce MacBook Pro 13" introduit la barre tactile OLED. Il est équipé d'un processeur dual-core Intel Core i5 « Skylake » et de quatre ports Thunderbolt 3.
Lid open problem: could not open more than 90 degrees
This weird problem just came since yesterday:
When I slowly open the lid, the screen lights up and my MacBook Pro wakes up as usual. I can log in, do normal stuff.
However, if I continue to open the lid and pass 90 degree point in opening it, the screen turnes to black, while the Keyboard & TouchBar are still working and I'm sure that the system is not sleeping. Just the screen turns off!
Anyone have any clue on how to diagnose the problem/resolve it?
Répondu ! Afficher la réponse J'ai le même problème
Indice 8
5 commentaires
I have this problem too. But sometimes gets as worse as 45 degrees for me, making it tough to use the laptop. :/ Went to an Apple authorised service center ( We don't have official Apple stores in India ), they told me that it was a display problem and I had to change the display. I don't think it is a display problem as it is working fine. Did going to the Apple Store solve the problem for you Liu?
par Partager
No, the person you spoke to is correct this is a display problem!
The new display design did away with a replaceable cable from the display to the logic board which is what failed here, you'll need to get the display replaced.
Hopefully, you can get the AASP to put it under a warranty exception. Good Luck!
par Partager
Oh, my warranty is over. I came to conclusion that this was a Ribbon problem after I read this answer ( I have the dark bands problem too ) Dark bands showing on my MacBook screen
par Partager
Go back to that question and take a look the new image i posted it will explain things. You are in the same pickle you could try cleaning the cable connection but I doubt that will fix things. I've now seen 10 systems! All with this problem! Need a new display unit. If you open the system you run the risk of Apple denying your extended warranty.
par Partager
I’m having the problem too since a few weeks. When I open the lid more than around 40 degrees it goes black. I can only have an active display when I keep the display under 40ish degrees. I paid around 2800 euro for my model, but Apple is not helpful here. I will see if my credit card insurance will pay under there warrenty extension. I will make sure they get the info that it’s most likely an design problem from Apple.
par Partager
Ajouter un commentaire
6 Réponses
Solution retenue
Best to bring this into an Apple Store as there is a known issue with the ribbon cables on some early units (defect). In addition the keyboard keys have issues. Apple should either repair or replace the system under extended warranty.
This was addressed in Apple extended warranty program 13-inch MacBook Pro Display Backlight Service Program
Indice 4
8 commentaires:
Thanks Dan, I'll go and check with the Apple Store for that.
par Partager
Has it worked?
par Partager
I've have two come in with bad cables Apple repaired both for free!
par Partager
Good to hear! Only thing is, my 2016 Macbook is just out of the year warranty, do you know if they still fix it?
par Partager
Yep! You may need to push a bit (move up the food chain)
par Partager
Voir 3 commentaires en plus
Réponse la plus utile
I can’t offer any tangible solution for your broken screen since myself is in the process of fixing it. However I urge everyone to log a ticket on Apple support site so that they are aware of it. Until enough people report the same problem, they will not open a quality program for it and they will not repair for free. Once a quality program is created for this specific issue, we can even get refunded for the repair cost we put in.
Update (09/05/2018)
I’m sorry to see more cases spreading globally, The Apple Store’s again continued to ask its customer to pay for the repair even though it is very obvious that it is a defective component.
Long story short, I too talked to a senior staff from the support team but got no help. I continued to reach out to customer relation, after an hour long heated discussion, she finally agreed to repair my display for free. Yet, the Apple Store did not agree to the decision, I had to pick up my system from the Apple Store and declined the repair first. The Apple customer relation then ordered me a repair box to ship my laptop in for depot repair. The depot repair was known to be a cheaper way for fixing device issue.
After that, my problem was fixed within 3 days and shipped right back to me with no charge on my side! I am happy with the result but it is sad to see Apple continue to treat it’s customers badly especially in situation as this.
Given many similar cases spreading globally, I’m sure it is a defective product issue but Apples refusal to look into it and continues to ask victims to pay for the expensive repair is just not right.
It might take another class of action to put this issue into a quality program.
Indice 4
8 commentaires:
Correct!
Most of the repairs have been under warranty or AppleCare+ service contracts so far. We are now starting to see these cable issues on systems which have now passed Apples normal warranty period.
While some folks have managed to get it still repaired under a warranty exception after a bit of haggling. I wouldn't be surprised more people will end up needing to pay for the repairs and wait for a proper extended warranty program is started.
Keep in mind the current keyboard repair program only happened after the threat of a few class action lawsuits! It may take that to get Apple to budge.
par Partager
I am having this exact same issue and it only started about 3 months after my warranty period ended. I brought it in to an apple store in Turin, Italy, where I am currently living and they said I’d have to pay for the repair. I then found out about this issue being quite widespread so I complained to the apple support chat folks and they directed me to a senior phone advisor who said the same thing. Now I scheduled another meeting at the apple store again and I will ask to see a manager... Any tips on how to take this further up the food chain so that I can get an exception/push for a repair program like with the keyboards?
par Partager
Helen, thank you for the info. I’m gonna try and keep pushing them to fix it... Not sure what else to say other than “I´ve been a loyal customer Bla Bla Bla” but i’ll try. Is there any chance I could use your case as an example of Apple actually fixing this issue for free? If so, could we get in touch?
par Partager
@hailunshyu - Happy & sad! Happy you got Apple to fix your system, sad it took that much effort.
Please fire off an email to big Tim (tcook@apple.com) giving him all of your details (both the repair ticket # from the Apple Store and the repair ticket # on the repair depot repair), make sure you express your love for your system (when working) and how you want to be a loyal customer. But, Apples failure to acknowledging this design failure after you've seen lots of others facing it is very worrisome and how you had to fight for the repair.
par Partager
@diegoaparra30 , yes you may use my specific case id as a reference if that will help you in any way. If you could leave me your email, I can send you the details. @Dan here has provided very good suggestion if you haven't read. I also like to thank @danj for being a great input regarding this particular issue, which had given me solid confirmation for where I stand when talking to Apple, thanks so much Dan.
par Partager
issue is re-opned here https://discussions.apple.com/thread/250...
Indice 0
1 commentaire:
This looks like the FlexGate issue! The Design Flaw Behind MacBook Pro’s “Stage Light” Effect
par Partager
Can anyone update me on this issue? My daughter's computer, a 2016 Model A1706 EMC3071, is suffering. At about 10° the screen turns on, at about 45° the screen turns off. Is Apple taking ownership of the problem, or, if not, can you point me to a repair guide?
Indice 0
1 commentaire:
par Partager
Hi Everyone, I am also having this issue with 15 inch MBP A1707. Please share any workable solutions if you were successful in solving this issue? Thanks.
Indice 0
Hi everyone, I'm having the same problem on a 13" MBP A1708 2017.
Any solutions?
Thanks a lot.
Indice 0
Ajouter une réponse
Liu Kai sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 35
Total : 27,040
