Aller au contenu principal
Assortiment de cartes graphiques (également nommées cartes vidéo)
97 questions Voir tout
Sapphire Radeon RX 570 8GB burned resistor(?)
Trying to understand what is broken here, so I can replace the parts.. believe it says r200 where the part is burned.
Any help is appreciated :)
My card:
http://oi67.tinypic.com/oqkbyo.jpg
rx580 (same pcb):
https://www.techpowerup.com/reviews/Sapp...
Répondre à cette question J'ai le même problème
Indice 1
1 commentaire
hmm noone?? :)
par
Ajouter un commentaire
5 Réponses
Réponse la plus utile
yes its a resistor with r200 and mr200 written above it but finding the value and package size could be difficult
Indice 1
6 commentaires:
there seems to be so many different physical sizes for them. and different wattage, etc.
what is the best approach here, do you think?
possible to use different r200s here (with different wattage etc), as long as the physical size fits?
thanks!
par
i would only be guessing as theres no schematic i would probably try 0603
par
most r200 is see are 1w 1% so any resistor around that
par
where i can get that...0603 r200? :)
par
you could probably get them on ebay just type in r200 0603, it will probably not have r200 on the top tho. the thing is how many ohms it will be
par
Afficher 1 commentaire en plus
Graphics card Schematics Sapphire Radeon RX 570/580 https://drive.google.com/file/d/1ylcnbtS...
B200 = R220
Indice 1
That is fuse for +12V supply.
If your fuse burn, you must check short circuit before u replace. I have same problem, the fan not have supply voltage. My fuse is good but the circuit no voltage out to fan.
Is any bodyhave a schematic for shapire rx580.? Please help.
Thx Rico
Indice 0
Just for completion sake. Reference designator R200 is a 20Kohm 5% resistor in what looks to be a 0603 package
Indice 0
I have broken RX570 4GB (ROG-STRIX-RX570-O4G-GAMMING)
4 pcs. Resistors 2.2 ohm near PU800 (7805) linear regulator for 5V is extensive heating, on picture I write resistance and voltage
I do not have expirience to fix this RX card, before i fixed older types cards like (GTX 660, R9 280X, …)
If you can help me please….
Indice 0
Ajouter une réponse
Ole sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 16
30 derniers jours : 65
Total : 3,154
