The HP Officejet Pro 8600 Plus is identifiable by its model number: N911g. Released in 2011, the printer can be identified by its brown finish and touchscreen control panel.
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
Hi @rh001 ,
A bit more detail will help us to help you.
What are you trying to do?
For example are you trying to copy documents by loading them in the ADF or in the paper tray?
If so what is the type of document i.e. what is the paper thickness and size etc?
What make and model is the computer that the printer is connected to if you are wanting to print to the documents that "will not feed"?
par jayeff
