Aller au contenu principal
The Apple AirPort Extreme Base Station is a wireless router first introduced in 2003.
4 questions Voir tout
External antenna for A1034 airport extreme
The A1034 has a socket for an external antenna to extend range. Where can i get one? what model # or part # do I need. Tried one on eBay but jack will not fit socket on A1034. Help!
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire
This is a very old AirPort unit. It does not offer any of the modern transmission security (only WEP which is very easy to beat!) In addition its 802.11b compliant only so its real sllloooowww.
Best bet is to find a home for it on a dusty shelf and get a newer WiFi unit. In fact Apple just announced its getting out of the WiFi router market! Apple exits Wi-Fi game, AirPort routers discontinued after stock sells out.
So you might find a deal on new one! Or, you might want to look at one of the other units which offer 802.11ac services.
par
Ajouter un commentaire
3 Réponses
Réponse la plus utile
An der Antenne ist eine 2 m lange Koaxialleitung dran, Mit dem entsprechenden Stecker, der in die Airport reinpasst.
Aus eigener Erfahrung weiß ich, dass sie wirklich was bringt.
English: A 2 m long coaxial line is attached to the antenna, with the corresponding plug that fits into the airport.
I know from my own experience that it really helps.
Indice 1
I did a web search and found: QuickerTek wireless antenna
Indice 0
2 commentaires:
They had at one point offered an antenna extender. It really didn't offer that much a better signal. I haven't seen one of the antennas in years! You could just find an older 802.11b antenna and plug it in if you can find one.
par
I'm sure the antenna is fine, but, as usual, apple-only socket.
Hint - 10" of of bare silvered wire works !
par
I’m sorry I didn’t see this question sooner. The correct cable is RF coax with RP-SMA female to MCX male connectors. I somehow figured this out and then found one on Amazon in September 2018, just six months after you posted. The product page was removed since then.
Indice 0
1 commentaire:
Oh, hang on… I found the new product page. It’s still $5.80 5 1/2 years later! Perhaps the only product not affected by inflation. It’s here: https://www.amazon.com/DHT-Electronics-c...
par
Ajouter une réponse
Doug Porteus sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 956
