External power brick for Xbox one X laptop?
Hi everyone, I'm still fleshing out the idea in theory of a reasonably thin Xbox one X laptop and the first issue would be power
The internal psu is 12v 20.48a and so I've found a 250w external power brick
http://meanwellusa.com/productPdf.aspx?i...
I'm not quite sure how I'd wire it. If the xbox uses fast on connectors I'm guessing I can't just wire the output wires to male connectors. I was thinking I'd need a DC to DC ATX converter and then go from there.
I've also got to consider connecting a monitor as well. Since max load on the Xbox is like 185 W would it be safe to use the same power supply for a laptop lcd?
Any help is appreciated thanks :)
Explain what you're thinking more. As you just said "Hi everyone, I'm still fleshing out the idea in theory of a reasonably thin Xbox one X laptop and the first issue would be power"... I don't really know what you're planning by that. Never saw you post about it, so I couldn't really know.
par Brett Johnson
