High CPU usage kernel_task
Hello everyone,
I'm having extremely high CPU usage and it's being caused by kernel_task.
When looking around on the internet for the problem most people note that their fans are going crazy and most answers to the problem seem related to the fans/heat of the mac book.
My fans are running just fine and the heat doesn't go above 40 degrees Celsius, so i'm kind of confused as of what could be the problem for me.
Tried booting it in safe mod and it was completely fine I had no troubles whatsoever, then I restarted it and after 10 minutes it was going up to 90% total CPU usage again.
(Fresh instal didn't fix it either)
I have no clue what the problem could be any help is very appreciated !
EDIT:
I just noticed that it hasn't happened ((yet)) when i'm charging it.
My macbook has been repaired in the passed and the battery has been replaced.
Could the battery be causing this issue ?
1 commentaire
Hello i solve this issue simply whit a very good clenaning from inside and changing de thermal paste. In my case it was a thermal issue, so, ones i can make temperatures back to normal again, everithing is working fine. Good Luck to u all
Saludos desde Argentina
par Julian La Delfa
